Accessing the ODB file with python with noPartsInputFile=ON ??
Hi.
In my model have have to apply boundary conditions in the input file directly on node numbers. I.e NOT on node sets.
I can only get this to work if I use "mdb.models['model name'].setValues(noPartsInputFile=ON)".
The problem is that I have to access the odb fíle with a script. I used to use a script looking like the one here below:
lastFrame1 = odb1.steps['Step-1'].frames[-1]
displacement1 = lastFrame1.fieldOutputs['U']
allNodes1 = odb1.rootAssembly.instances['PLATE-1'].nodeSets['NALL']
Disp1 = displacement1.getSubset(region=allNodes1)
But, with the noParts turn on, how will this scrips look then, if I need to access the displacements in the odb file?
Anyone knows how to solve this?
