Silly question re closed loop circuit
If I connect a pump discharge to the suction, fill it will water and seal then turn on the pump does the pressure in the pipe rise or does the temperature just go up.
If the pressure rises due to the pump head them where does it stop?
RE: Silly question re closed loop circuit
Ted
2) The pressure in the system will vary from Pv at suction, to Pv plus whatever the pressure equivalent is of the differential head being produced by the pump at any given time corresponding to its instantaneous flowrate (see pump curve), at the pump's discharge.
3) Continued heat input will warm the fluid, raising its temperature, causing the vapor pressure to raise, and in turn, the pressure at all points in the loop will also rise.... goto item #1.
BigInch's post details the fun unbounded heat rise until failure results!
We have a circuit which pumps liquid ethane into a pipeline. On this circuit is a minimum flow/maximum pressure controlling spillback, which goes to an accumulator on the suction of the pump.
If the pipeline shuts in, the recycle takes over, and we can see our pumpage temperatures rise quite quickly. There's no way to cool the pumpage, and there is only minor hydraulic loss in the system. Eventually, the ethane reaches a near vapor condition and the pumps vapor lock.
Of course, ethane is a different animal than water, but it still illustrates how fun recycle systems can be!
