Torsional mode frequency and supply vibration
I am making a design of a blower. The impeller is rigidly coupled to the motor. Shall I design the system torsional natural frequencies to be above  motor supply frequency (60Hz)? What about 2 x supply(120Hz) ?
Many thanks!
-S
RE: Torsional mode frequency and supply vibration
Some ideas on torsional excitation:
120hz is an important torsional exciting frerquency since it exists for single phase motors or unbalanced 3-phase motors.
I don't think 60hz is particular important.  During DOL start, there is torque oscillation at a frequency (1-s)*60hz... but should not remain at 60hz for long.
I would think running speed and 2x running speed may be good to avoid.  Possibly number of blades times running speed also.
Vfd could make life more complicated.
(2B)+(2B)'  ?
Thanks Pete for your quick informative post.
Actually, the case here is inverter driven 3-phase motor, so life is complicated :) Sorry not mention that in my 1st post.
But anyway, you think that 1x supply is not that significant excitation as 2x supply? Resonance would be there but with a smaller amplitude?
