Erosion Control
Erosion Control
Erosion control blankets are good to stabilize steep slopes to avoid runoff to natural areas. Are they needed in areas like steep slopes within a landfill or the slopes of the internal side of a detention pond, etc.?
RE: Erosion Control
RE: Erosion Control
Type 1 (cheap) is used to provide minimal erosion control and mostly helps the vegetation to become established. Seeding is required and the vegetation provides the erosion control. Hydroseed / hydromulch might be a good alternative.
Type 2 (expensive) is a turf reinforcement mat which provides considerable erosion control, even without any vegetation. Seeding and mulching are required.
RE: Erosion Control
RE: Erosion Control
RE: Erosion Control
But most of the time our clients do not maintain the slopes, do not irrigate the slopes, and we very rarely are dealing with non-erosive soils. So, unless you have a project with those unique characteristics, blanketing all soils steeper than 4:1 is a good practice.
RE: Erosion Control
