Weird 3D rendering issues
Hi, my friend is having some problems when rendering 3D models as anything other than static wireframes. Looks like this: h ttp://i638 .photobuck et.com/alb ums/uu101/ Semorghope /nx.png?t= 1297353782
Rendering a simple cube for example works just fine, but as soon as there is anything that breaks up the faces this happens. However, I think that this is probably due to graphics card (or possibly OpenGL/D3D, whichever NX is using)drivers rather than some faulty setting in NX itself, however, I'd like to hear if anyone has any suggestions...
Computer is a laptop with an integrated Intel GMA 4500M card running Windows 7 64-bit. Drivers are up to date.
Have tried re-installing NX, clearing settings from AppData, reinstalling gfx drivers... Going to try and run some other 3D application and see if the problem is specific to NX or not.
RE: Weird 3D rendering issues
You have to check here:
h
If it is I do't think there's much help available.
Does this Graphic Card supports Open GL?
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
Yes, the card does support OGL, tried running the old Quake3Arena demo which ran flawlessly.
Thanks for the reply. :)
Go to:
Preferences -> Visualisation Performance
And play abit around with Fixed Frames and a bit more, and see if it improves...
You can also do an Evaluate Graphic Performance, it is in the same SScreen, but under the Tab General Graphics
Best regards,
Pascal,
View -> Camera -> Capture and Edit...
...and going to the section of the dialog labeled 'Clipping' and hit the 'Fit Planes to Extents' button.
Also, you may wish to go to...
Preferences -> Visualization Performance -> General Graphics
...and at the bottom of the dialog section titled 'Session Settings' you will find an 'Evaluate Graphics Performance' button. Select that and the system will perform a series of test and will give you report as to the best NX display settings/options to get the maximum performance from your particular graphics card/driver combination.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
