Variable Radius values not visible
Hi all
How do you make the radius values visible, I'm doing a variable radius, but the darn things are not showing up.
RE: Variable Radius values not visible
radius values are to be defined on points (or planes) along your fillet edge. Once those points or planes are defined, you can set a value for each location.
Eric N.
Could you capture the picture for us? I would be great.
Could you capture the picture for us? It would be great.
Thanks for your reply's, but they are now visible. Not sure why they weren't showing up, but it seems to have fixed itself.
