Ultrasonic on Incoloy 825 (cooler header)
Hallo,
Just want to ask, can we perform UT on the incoloy material without calibrating it with incoloy 825 calibration block but using CS calibration block as a reference and then adjusting the wave velocity in the UT equipment itself as we know the wave velocity for incoloy 825.
Any reference code(s) which I can refer?
Cheers
Cheers
RE: Ultrasonic on Incoloy 825 (cooler header)
You would come closer using a 316SS as a reference.
The real issue is that if you are looking for specific defects then you need to have a manufactured version of that in your ref piece for sizing. Otherwise you are only guessing.
Plymouth Tube
No.
So we have to look for standard reference block made from incoloy 825?
Plymouth Tube
