Controlling Location of Datum Targets in Draft
Maybe it's just 'cause I'm still stuck on V19 but, how do you control the location of datum targets in draft?
When I did it before I basically drew some geometry in draw in view, placed the datum targets on that and then deleted the geometry & dimensioned to the datum targets.
However, there's got to be a better way right?
I can't seem to get dimensions to datum targets to be driving dimensions.
Any ideas?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Controlling Location of Datum Targets in Draft
Hi kenat,
I'm not sure what you mean but you can leave the geometry drawn in view, then hide it by moving it to the layer Auto Hide.
It will then not show when you exit draw-in-view
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Ah, I hadn't thought about layers.  I suppose that might do it.
Thanks.
It just seems like it would make sense for you to actually place driving dimensions to the datum targets and avoid having to sketch in geometry.
It works - I use it for dimensions of any graphics drawn in view.
bc.
Quadro FX4600.
Hi Guys
Certainly does work. Draw in View is quite powerful in my line of work.
I have found that when I use GD&T and Datum targets, it works best for me to connect them to a dimension or edge using a leader line.
I can then hide the leader line, and the datum target or tolerence block will move with the view  and or dimension.
It works like a callout to a hole, just connect the anchor or leader to a dimension or face.
It is then locked in place.
-av8errr
ST3
xw4600
3GB RAM
2Quad CPU
3.00GHz
Sorry, my last post applied to datum frames or feature control frames.
