pH calculations for process streams
Hi All,
I am trying to calculate the effect of reducing NaOH dosing rate on the pH.
Its difficult to explain so I've attached the excel file.
Any tips are well appreciated!
RE: pH calculations for process streams
Sorry should add that the reason why I am reducing the NaOH is that I am adding milk of lime solution in the preceding stages.
I am aware that the pH will increase significantly which is why I need to reduce the NaOH in the preliminary steps and set up a new pH set point.
I am trying to calulate how much the pH changes for the addition of milk of lime solution (reducing NaOH dosing rates)
