DRIPPING VALVE
DRIPPING VALVE
I need a valve to slow the flow of water to a drip. This is to create a trickling effect over a small pool of water. damn architects, lol
any recommendations?!
thanks
thanks
RE: DRIPPING VALVE
It sounds like what you need is a solenoid valve that just turns on and off very quickly. Doing this is a small line that has little pressure in the line should enable you to get a small amount of water through the solenoid and to "drip" into your pool creating the effect you wish.
The solenoid is can be air or electrically actuated to turn on and off. It sounds like you would need electric, hooked up to a timer.
RE: DRIPPING VALVE
thanks
RE: DRIPPING VALVE
RE: DRIPPING VALVE
or you can use a needle valve as suggested by hero123, swagelok is a good place to get acquainted with needle valves...there is a wealth of available designs for all kind of applications.
HTH
Saludos
a.
RE: DRIPPING VALVE
