Point Loads in Simulation Express
I would like to know if it's possible to do point loads in Simulation Express, or pressures over a selected area not the full size of a face. If so, how do I do this?
I'm simulating a small cylinder pushing on the centre of a larger cylinder.
cheers
cheers
RE: Point Loads in Simulation Express
For a pressure over a selected area, you just have to cut the face and apply the load to the sub patch. If you have ST3, there is even a tool to do an offset edge cut which should be perfect for a circle in a circle.
Mark
