CE marking of low volage 1 to 5hp induction motors
Dear gurus,
I would like to know exact applicable EC directives and corresponding harmonized standards for CE marking of the mentioned motors used in air conditioners.. one Motor manufacturer said ( the same type as ours) in its AD that LVD only applied. Is it possible to test by ourselves for compliance with EN standards?
Please help me with this matter.. thank you
RE: CE marking of low volage 1 to 5hp induction motors
No, not any more. Where the LVD applies, you need to cooperate with a certified test lab.
They will also tell you exactly which directives and standards apply.
Benta.
Per the EC website (see link below):
CODE
In short, you do not need to use an external test lab for LVD conformance testing. However, if you are not familiar with the standards it may make sense to use an external lab because they will know the tests that are required.
http
