Value for Pile shear n Anchore force in slope stability analysis
I have very simple question, my head is not working
How to get Shear value or Anchor force to put in slope stability anaalusis.
My concept- for Pile Pasive resistance from downward slope soil above failure plane (if failure plane is specified)? What if u ingore such soil resistance ? No pile shear value ?
RE: Value for Pile shear n Anchore force in slope stability analysis
It is clear from the description above that the pile will have to take the tributary containment load, assigned to it by the analysis. It is also clear that if piles are used in the containment scheme, it is because at the projected placement they are thought to positively contribute against slippage of the masses above not yet properly contained (and so not influencing them); this usually means that the piles are in such disposition that are thought to anchor themselves well beyond the expected surfaces of failure; so, as you see, counting on gained fixity, that is always to the expense of passive action on the sound soil thought not to be subject to slippage.
I am assuming you are using LE software like Slope/w or Slide etc where you can simply slot in a pile and therefore assume a shear resistance. (A structural eng will be able to give you the shear capacity of a pile of a certain diameter)
I think I am right in saying there is a wider problem with this approach, which by the way I see quite often.
The problem is as soon as you put the pile in place you change the shape of the failure surface behind the pile. Ignoring this for a minute, I dont think you can get the (pseudo)active pressure distrubution on the back of the pile from the LE software, so you start straight away getting into the realm of overestimating (read guessing) the pressure on the pile. The passive resistance doesnt reach the normal passive limit either because its sloping.
