DN Paint Color vs. Fed. Std. 595 Color
I have a specification calling for color DN 3493 (Gray Type 1). I believe that it is equivalent to Fed. Std. 595 color 36081 which is a dark gray.
Is there a comparison chart available that lists DN vs. Fed. Std. 595 numbers?
ERAU82
ERAU82
RE: DN Paint Color vs. Fed. Std. 595 Color
I am not familiar with DN colours. Your number definitely is not RAL if it is indeed gray. Here is a list of FED STD 595B colours with RGB codes. If you can find equivalent DN codes, you can work out the answer to your question.
ERAU82
