Using XPSWMM to create Flood Maps
Has anyone ever used XPSWMM to create flood maps? I have an urban area (mostly closed conduits) and have been asked to create flood maps. I have created a DTM in SWMM but have been unsuccessful in displaying the flooding extents. Any ideas?
RE: Using XPSWMM to create Flood Maps
Civil 3D has a SWMM engine as a subscription advantage pack. What file format is your DTM and what software are you trying to display it in?
How big is your area?
I've used XP-SWMM to do flood plain modeling before, but I've never used the DTM portion of the program.  I cut sections in Land Development Desktop, entered approximations of them in the section geometry editor of XP-SWMM, did my analysis, and then drew the extents of the flood back in AutoCAD by hand.  Took me about a day.
I finally yoinked an educational copy of Civil3D, so I plan on goofing off with it sooner or later.  So far all I've discovered is they changed the LayIso command to be a big pain in my ass.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
If you have a river station/WSE from your hydraulic model, it's really easy to create the water surface plot by creating an alignment, profile and then corridor model in InRoads or Civil 3D. You use a template/assembly that shoots horizontally and daylights at the existing ground surface. Much easier than tracing contours and interpolating from cross-sections, which I've done in Terramodel with HEC-RAS results. Of course, Civil 3D can import HEC-RAS output and may be able to create a surface off it; I've never done the reverse trip, only used it to create my HEC-RAS x-sections.
only problem with shooting horizontally is that flow splits (I mean secondary channels) are missed.
