3D plots with Mathcad 13
I tried a 3D surface plot and it looks awful because it repeats the axes labels and the numbers at each of the ticks a long the axes.   Does anybody know of a fix for this.  The graph is useless as it is.  I can't use it in an article or publish it.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
RE: 3D plots with Mathcad 13
you must do left click at plot and select format plot
 . And there are some option to delete the labels and numbers .
