Datum use with a pattern of a pattern?
See My attached jpg.
Does this Datum/Pattern say what I want it to say?
What I want it to say is:
Give me a pattern of large circles located within .02 of Datums A,B,C. And around each large circle, 4 small circles within .005 of their basic location relative to each large circle the 4 are around.
Thanks for you help.
RE: Datum use with a pattern of a pattern?
This method is implicitly allowed by ASME Y14.5M-1994 in section 5.7, fig 5-39 and more implicitly in Y14.5-2009. Not sure what or if your using either of these standards.
By the way that second "implicit" should be "explicitly".
The holes are not thru, so there are 12 of the large ones, and 24 of the small ones.
Thanks for pointing me to 5.7 and fig. 5-39. Somehow I misread that section. If I understand correctly the attached jpg is how it should look.
Thanks again prdave00
Second print shows your intent quite well.
I have just one comment: Referencing only E datum individually in position FCF for each set of 4 holes means that each of these patterns can rotate around corresponding large hole without any limitation. If you wanted to somehow constrain this degree of freedom, you would need to add datum C or D as a datum feature after E. This is worth to consider if you want to keep patterns oriented relative to outer edges.
Peter Stockhausen ://www.lin kedin.com/ profile/vi ew?id=3006 4526&t rk=tab_pro
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
http
Peter Truitt
The pattern of large holes (really they are cutouts of different depths) could have a positional tolerance of much more than .020" and fill the actual need.
The positions of the 4 tapped holes around the large hole are locationally important, but I intended it to be ok if the 4 hole pattern is rotated around the big hole relative to C and D.
Yes It would seem to me too that referencing Datums A or B for the patterns on their respective sides is most correct. I'm not sure what I have is technically wrong the way it is. But I am sure that most any shop will understand what I want. Assuming they understand GD&T.
Each pattern of "1 large and 4 small holes" are essentially independent of all the other patterns.
I mistakenly looked at the Tol for a #1 screw when I filled in the .005, it should be more like .008 for a #2.
On the last drawing you posted the "12X INDIVIDUALLY" is correctly applied to the datum feature E symbol, but I think the other "12X INDIVIDUALLY" is in the wrong place... It should be moved to the position tolerance that applies to the four small holes around each datum feature E.
I hope this helps.
Dean Watts
www.d3w-engineering.com
did I miss-interpret?
So not only was 12X INDIVIDUALLY misapplied to the large hole, rather than to the threaded holes, it should also have been applied as a 12X PATTERN OF 4, and not INDIVIDUALLY.
Attached jpg. is how I think it should look now.
If you have a Y14.5-2009 take a look at figure 7-37, on page 128. The part in that figure is very similar to yours.
I think:
1) The note of the position tolerance applied to the four hole relative to E should just be "12X INDIVIDUALLY". You have a "4X" that applies to the position tolerance and to the 12X INDIVIDUALLY note as well.
2) Mentioned in prior posts is the need for a better primary datum feature... E (all 12 of them) are too shallow to reliably orient a datum reference frame so the inspector will likely keep their orientation to A... This being the case the DRF should be |A|E|, & maybe for 6 of the 12 it should be |B|E|.
3) Rotational best-fitting must be included in the evaluation of these position tolerances (with no datum feature referenced to constrain rotation about datum E)... I think it is likely better overall to go ahead and reference either C or D, so |A|E|C| or |A|E|D|. This will be simpler for a less sophisticated metrologist to evaluate. Of course this may be a step away from your functional need, so |A|E| & maybe also |B|E| would still be worth considering.
Dean
Looking at it again, I agree either the 4X or the "OF 4" must go.
One of the things that has troubled me all along with regard to the 12X INDIVIDUALLY notations, is that since I have used a detail circle that is already called out as 12 PLACES, does that negate the need for the 12X INDIVIDUALLY and/or 12X PATTERN?
E is defiantly a relatively poor datum FEATURE in all cases. But using just E, does describe the design intent. Where as adding other datums adds unnecessary constraints from a "function of the part" perspective. Though it may be more troublesome for a metrologist to have only E.
www.infotechpr.net
http
I obviously don't know the function of this part, but it really looks to me like you have two sets of six features (related to A|C|D and B|C|D), rather than one set of 12. Mostly because having all of the holes related to one face strikes me as odd with no orientation control between the faces. Not illegal, but odd. I would expect either A & B to have a parallelism requirement, or the holes to be oriented only to their respective side. For that matter, why datum B at all if nothing relates to it?
Steve, you are essentially correct. There is no control between A and B other than the +/-.050. That is because further refinement is not needed in this application. There is however a // relationship between the bottom each pocket and the face from which it's cut. Functionally, due to the shallowness of the pockets it will not matter if they are referenced from A or B, so long as they are // within spec, to the datum from which the // spec is applied. As such for simplicity I chose to use 12X rather than 2 6X, since it does not appear to be either wrong, or more confusing.
Thanks again to everyone for their input.
www.infotechpr.net
http
www.infotechpr.net
http
www.infotechpr.net
http
It appears that you are improving the drawing. I agree with pmarc that you should consider clocking the hole patterns around the large holes. Currently the callout will not control rotation of the pattern around each large hole; unless you aren't concerned if the 4 hole patterns could for example be at 45 deg to one another.
Datum C in the lower view is not the surface you are dimensioning from in the top view. Basic dims need to originate from a datum. In this case the dims are inverted. The 0 and 5 should be swapped as far as the current datum C surface. The other dims need adjusted as well, originating from datum C.
I also believe that in baseline dimensioning that there can be only "one" zero. In detail K this is confusing to have another "zero". The callout for the patterns reference's datum E and implies that those dimensions are from datum E, 12 individual places. That would be the 2 center planes intersecting the axis of datum E. IMO that is good enough without putting a zero at the center of the large hole datum E.
I certainly would remove datum B from the drawing unless it is or will be referenced somewhere that is not shown.
Ligo,
If the drawing is 1st angle projection then your dimensions in the top view are correct. My bad for "assuming" it is a 3rd angle projection.
I'm not clear on what you mean by dimensions from Datum-C not being consistent between he top and bottom.
Do you have a reference for Ordinate dimensioning not being able to have a second zero in a detail view? That is one of my concerns and I'd like to lock it down.
The bottom horizontal line in the bottom view representing datum C is the most upper horizontal line in the top view. The line which has dimension 5 should be 0, since basic dimensions originate from a datum. The drawing currently shows datum c in the bottom view and is dimensioned from the oppostite end of the part in the top view. This is basic orthogonal projection for 3rd angle projected dwgs.
I am presuming this part is dimensioned with 3rd angle rotations. 1st angle projection would be another story.
Baseline dimensioning should have one zero for x, one for y, and if necessary one for zero at one common origin. This is per the part, not per each view. If you took away detail K and put the zero for the large hole in the upper view where detail K originates from; then you can see how confusing this is.
You would have zero at the left edge of the part and zero at the center of the large hole.
I tend to agree with your logic on baseline dimensioning methodology, I but I'm not seeing anything in Y14.5 to say so.
