Pressure Test of Nitrogen Cylinders
We have replaced the valves of some Nitrogen Cylinders.
What kind of pressure test we can carry out on these cylinders?
Can Pneumatic or Hydro Test be done on these cylinders?
Will it go as per ASME Section VIII Div 1 ?
If yes, how to create pressure inside the cylinders?
RE: Pressure Test of Nitrogen Cylinders
Your version sounds very logical....! HT may not be needed..!
However, I feel that sicne the valve is a threaded valve, does it not make mandatory to hydro test the cylinder & new valve as an assembly??
Just a lateral thought...!
If these cylinder are on damage, from the people that fill the cylinder with N2 it is there responsibility to test the cylinder at some interval. The last inspection information is stamped into the cylinder near the top. Take the latest date.
Do a little search on "Compressed gases' and you will find a lot of information on the treatment and testing of said cylinders. The DOT did regulated these cylinders.
This is not a weld repair, we just replaced the valve with a new one. we did nothing on the tank body.
Tanks are in sound condition and well protected by coating.
The last hydro test date will be stamped in the shoulder of the cylinder, indicating month/year (01/09 for jan 2009), with the test facilities registration # in the middle, and if they are a DOT 3AA series tank (which will be also stamped on the shoulder), then the hydro test pressure will be 5/3's the working pressure. So on a 2400psi cylinder you'd have a 4000psi test pressure, which will be performed in a water bath hydro test.
The water bath allows them to measure the expansion of the cylinder at max test pressure, then measure the contraction after the pressure is released. If there is more then 10% permanent expansion, the cylinder is condemned.
Jim
