what is this coating
Came across this set of knives and I'm trying to figure out the what the coating is (http://www.stelton.com/ProductView.aspx?id=453)
specs:
material: forged stainless steel
special coating is easy to clean and hygienic
soft matte black coating has superb grip
FDA approved
I did a little bit of digging and came up with nothing, so I thought I would toss it up to the ET braintrust. Any thoughts?
specs:
FDA approved
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/_chrisloughnane
RE: what is this coating
one in your post. I believe you knives have one coating the
whole knife and the grip is a second coating to increase the grip. The description in several places talk of a rubbery coating on the knives. This type coating could not be on the blade part.
Houts has a Duracoat system for guns and probably knives.
Lauer has another Dura Coat.
Rentless has knives that use a Duracoat or Dura Coat type coating.
Bench Made has 3 coatings for knives. the number may correspond to the Paraloid materials from Dow.
http://www.houtsenterprises.net/
http://www.lauerweaponry.com/
h
http:/
William Gunnar
http://www.IndustrialCoatingsWorld.com
http://www.birchwoodcasey.com/presto/index.html
http://www.heatbath.com/heatbath
