Get Manual Selection from view -> API Macro
Hi to everybody..
Within the Macro I'm going to create, there is a part in which I wish to get some entities selections from an assembly.
I explain it better.
At a certain point of the macro, an assembly is opened.
A CommandButton in a Form says "Select the XXXX plane".
The macro now has to wait in standby that I select manually the plane I desire from the Assembly view, "store" this selection in a variable and then, create a "Plane1" which is coincident with that plane of my selection.
This is the code I thought to, but I'm on the wrong way .. :(
I wish you can help me..
thanks a lot.
thanks a lot.
Quote:
Dim swApp As SldWorks.SldWorks
Dim feature As Object
Dim SelMgr As SelectionMgr
Set swApp = Application.SldWorks
Set Assembly = swApp.ActiveDoc
Set SelMgr = Assembly.SelectionManager
Form.Hide
Set feature = SelMgr.GetSelectedObject6(1, 0)
feature = Assembly.GetSelectedItems()
Set feature = Assembly.FeatureManager.InsertRefPlane(swRefPlaneReferenceConstraint_Coincident, 0, 0, 0, 0, 0)
RE: Get Manual Selection from view -> API Macro
If I use this option:
a plane is created, BUT the macro doesn't wait my manual selection. The plane created is coincident to another plane I don't want..
