Info. on old C-channel steel joists?
I'm analyzing an existing structure that has what appears to be cold-formed steel joists. They are 8" deep, with a 2" flange width, and a return lip, similar to standard SSMA joists/studs. The odd thing is that the punchouts are spaced 6" o.c. The punchouts are "football" shaped - 4.5" wide (along the joist's length) and 2.5" high. There is only 1.5" between punchouts, along its entire length.
I'm wondering if anyone has any design information on these joists? How do I analyze these joists to determine their capacity?
Thanks!
Thanks!
RE: Info. on old C-channel steel joists?
