question on NACE MR-0175 part2
Dear all
This question is regarding the NACE MR-0175 specification, part 2 for carbon and low alloy steels.
We have determined based on the level of partial pressure of H2S and in situ pH that we fall in SSC region 1, based on that we have to follow Annex A4 corrrect?
If we were to follow A4 then the hardness requirement are listed upto 300hv10 but based on section 7.3., the hardness requirements are 22HRC (iei 250HV10), so I am a bit confused what hardness requirements are to be followed for the parent pipe as well as the weld.
If anyone can help me on this. It would be greatly appreciated
RE: question on NACE MR-0175 part2
So, do you feel lucky with a suggested 300 HV versus a required lower value from Table A.1 and Clause A.2?
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
You might like to read this:
http
h ttp://uk.l inkedin.co m/pub/terr y-roberts/ 28/a9a/a10
