AISC Design Guide 2
AISC Design Guide 2
I am analyzing a penetration that has been cut into a HSS 8 x 4 x 3/8" square tubing member.
Can AISC design guide #2 for Web Openings be used for shapes other than wide flange beams?
After reviewing the sizing procedure, I see no issues with applying them to HSS tubing shapes (assuming stability criteria is met). Am I correct?
Thanks in advance.
Thanks in advance.
RE: AISC Design Guide 2
