Instrument or method to analyze Si and SiO2
Hiii..
I have a powder which consists of Si, SiO2, Fe3O4, FeO and Fe. I really want to analyze the conversion of Si to SiO2. Anybody what kind of instrument or method that i can use to measure the conversion?
Thank you very much for all of the suggestion
RE: Instrument or method to analyze Si and SiO2
Look at the instruments from Oxford and Innov-X for analysing your material.  I think it would be an analysis similar to iron ore.
I would contact both companies to check the feasibility of using there instruments either by rental or using a lab that has the instrument.
I've never used either, but it looks like the Oxford Instrument may better suit your needs.
http://www.oxinst.com/products/xrf-analysers/quality-control/x-supreme8000/Pages/x-supreme8000.aspx
http://www.innovx.com/en/applications/mining
Rentals:
http://www.innovx.com/products/saless
thank you...
i think this is spectrometry,  my powder contains of Si and SiO2, do you think this instrument can check the conversion? I am affraid that this instrument can distinguish the Si from Si and SiO2.
i am grateful if  u can reply my answe.
That question would better answered by the instrument manufacturer.
I'm sure it can be done though it may require and extra step in the assay.  Putting a little thought into your problem a big question looms, How homogeneous is your material and size of the material.  Like a lot materials getting a representative sample is about 60% of the analysis.
thank you very much...
