where can I buy pieces like this?
Hellow all!
I need a plastic/synthethic pinion wire like the one in this picture. It is 7 cm long and 1.5 cm diameter and 12 teeth. Anyone knows where can I find this kind of pinion? I don't care if it is sold in long pieces, like 1m bars and then I have to cut it to.
Pinion wire -> http://flic.kr/p/9gadnp
               http://flic.kr/p/9gdjYE
Thanks a lot!
RE: where can I buy pieces like this?
Any plastics extrusion company should be able to help you.
Where in the world are you situated?
Adriaan.
I am a Mechatronics Engineer/part time Master's student from South Africa.
www.martin-electronics.co.za
Where is it used.  Does it drive a belt or a gear?
Might try 'Nordex'.  They've got a ton of parts, also cad files available.
