Can't insert a Design table in a part!
I have SW 2008 SP 5.
I have lots of parts with design tables, and can edit them no problem.
I usually use configurations, today I tried to create a design table.
insert - design table
and nothing happens, been throught all kinds of tutorials, new parts.
again nothing...
Is there a check box in options I missed that disables this?
Thanks in advance,
Keith
again nothing...
Thanks in advance,
Keith
RE: Can't insert a Design table in a part!
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Yes, I have office 2003 installed...
Also, when I try to create one, the options (properties) windows open just like in the tutorials.
I set my options, hit okay and nil...
Keith
"I think the surest sign that there is intelligent life out there in the universe is that none of it has tried to contact us."- Bill Watterson (Calvin & Hobbes)"
SW with the help of my VAR gave me a this command "Regsvr32.exe %Windir%\Syswow64\Ole32.dll"
You have to open a Command window - Start\Run and then you can RMB (Right Mouse Button) and paste the link and click "Enter" to run it. Its suppose to the link between SW and Excel... I am running 64-bit so if you have 32-bit machine it might differ. Check out the SW knowledge base, you should be able to find it there.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
