Making "permanent" plastic bubbles
I know this stuff exists and I've done much net searching but I can't find a name for a water soluble plastic-like polymer that can be used to make relatively strong and permanent bubbles for kids to play with. Maybe someone here knows.
RE: Making "permanent" plastic bubbles
Try polyvinyl acetate (PVA). It is dissolved by water (becomes milky white suspension)and easily dissolved by a number of organic solvents eg acetone as a clear liquid that dries to a clear plastic. Many fibreglass & resin sales outlets sell it as a brush/spray on liquid-to-film mould release. I don't know the toxicity of PVA and you would certainly need to check this before trying it. Hope this helps you.
<nbucska@pcperipherals.com>
Best Regards
Morten
Do you have a name for the product so I can look it up? I can get more info if I have the name of the manufacturer. There might even be useful info on the ingredient label. I appreciate your input, thanks.
Jim.
What you see here is the best info I've been able to find on the subject of long lasting bubbles. For more ordinary bubbles, using a soap like Dawn dish soap, adding some glycerine to the formula, and letting it age overnight before use seem to be the most common adjustments to get good bubbles.
I think you got on to something with your "long lasting non permanent bubbles" glycerine comment. It made me think how would gelatine or room temp setting agar agar go. Being such a thin film one of them might emulate a rapid set polymer.
Has anyone tried either?
Good idea, I hadn't thought of those. Sounds like it's worth a try. Thanks.
I can't speak on the agar solution, but I think the commercial product you're thinking of is Magic Plastic Bubbles: http://explore4fun.com/magplasbub.html
Hope that helps,
/m
