Ansys WB - Inputting Stress Strain data
Hi all,
I am trying to model Fibre concrete in direct tension in Ansys Workbench.
I want to find a way to input the tensile stress-strain curve from the experimental work I conducted so I can model the post yield behaviour. Currently, I can only input the maximum tensile strength.
I having imputed solid65, compression stress-strain data, young s modulus and poisons ratio.
If anyway can help, I would be very grateful,
RE: Ansys WB - Inputting Stress Strain data
I think you're looking for 'Multilinear Kinematic Hardening' in the 'Plasticity' section of your materials Engineering Data.
Hope that helps.
