Which one is better Bromine or Calcium Hypochlorite
Hi all.
Need help to decide b/w calcium hypochlorite and bromine tablets.
Need your experience. Please help me in comparison technically. I know there is no comparison comercially.
RE: Which one is better Bromine or Calcium Hypochlorite
This link should answer all of your questions:
h
Hypobromous acid predominates below pH 8.7, making bromine donors more effective than chlorine donors in alkaline cooling waters, especially where contact time is limited.
ht
However, chlorine is considered to be a stronger oxidizer than bromine and is a less expensive chemical. Bromates are considered to be more hazardous than chlorine and are more regulated.
There are some products available that have both chlorine and bromine. You may consider alternating your use of these products since some organisms tend to acclimate to the use of a single product.
Greetings.
Manuel Arguelles
Service Technican
Venezuela.
