Detecting ice in water pipes....by using a motor?
16
We  design domestic water temperature controlled showers.
Stepper motors adjust hot and cold flow rates.
If the water in the pipes is ice, and we try and rotate the stepper valves, these valves break.
So do you know how we can detect if the water is ice or liquid.?
...its not terribly useful to use a thermistor....anyway, we already have a thermistor in the "mixed" pipe outlet....since water can be at zero degrees and liquid if it is agitated ....(made to flow a bit)
...the problem is that if our thermistor reads zero degrees or therabouts, we don't know if its ice or water....and we have to disallow the shower form turning on.....and customers are unhappy when there shower does not work.
I  was thinking that we could put like a small rotary "fan" in the water pipe, and energise it.........we could then measure the current flow to it to see if the water was ice or not....because if it was ice, then the "fan" would not be able to rotate and it would be in "locked rotor" state.....as such ...would more current flow to its coils?
...i would have thought  so , since the back EMF would be lower.(?)
....because if less electric current did flow, then we could measure this current to assess whether we had ice or liquid water in the pipes.?
RE: Detecting ice in water pipes....by using a motor?
How about a water detector on the floor below the pipe.  Because if you have ice in the pipe - the pipe has broken.
Where in the world are you that the pipes can get that cold in a shower??  I sure don't want to take a shower in those conditions!!
Most stepper motor systems are designed to stall rather than break. Make whatever is breaking stronger. If ink jet printers broke whenever a motor stalled none would last a year.
the shower unit is placed in the attic...which is very cold in winter in  many parts of USA and uk.
sorry it isn't so much the steppers breaking, as the cold water is frozen solid, and so the hot can come through alone and scald the person becasue theres no cold water mix.
"Most stepper motor systems are designed to stall rather than break. Make whatever is breaking stronger."
Or use a lower torque stepper motor, or a magnetic torque-limiting clutch, or...
" it isn't so much the steppers breaking, as the cold water is frozen solid, and so the hot can come through alone and scald the person becasue theres no cold water mix.  "
What commands the stepper motors?  Presumably a fairly sophisticated circuit.  A simple flow switch, or a pressure sensor between valve and shower head on the cold water side would tell you if the flow is inadequate.  Presumably a thermistor in the shower head would command the hot water valve shut when the temperature spiked, is the valve speed to slow to do this?
Could you wrap the hot & cold water lines together with insulation or such - so that both stay warm??
What about checking the pressure after the valve, no pressure=no flow, or listen for flow with a microphone.
I'm glad I've still got my 30 year old hot and cold valves in my shower.
btrueblood:
steppers are commanded by a microcontroller.
-the uC reads thermistor temperature of a thermistor in the mixed pipe, just after the stepper valves.
....you're right we can't risk too-hot water getting up to the shower-head as scalding is then a risk.
badservo:
Unfortunatley, we cannot just command the water flow and then check to see if its flowing...because then it would be too late and hot water (not mixed with cold) would be on the customer.
hot, with cold water  must always be able to flow together so that we can decrease risk of scalding...if theres no cold becasue its frozen, then the  pure hot water can get through and scald before the uC has time to shut off the valve.
MiketheEngineer:
It wouldnt help to wrap hot and cold together because when the shower is not used, the cold will eventually still cool down to the point where it gets to around zero degrees.
Adapt a moisture meter that works on capacity. If the meter reports that the water is drier than water that is because it has frozen. Resistive measurements may help also.
I've never seen this done though. I Canada we have quite a few techniques to prevent the water from freezing in the first place.
Bill
"Why not the best?"
Jimmy Carter
A flow switch in the cold water (ice) line that would cut off the motor power supply either at the start or even during the showering. (Pity the guy who had just shampooed his hair)
Muthu
www.edison.co.in
edison123
Thankyou...........
-with our showers, if the customer switches it on...it won't actually come on in the first place if the thermistor reports  a temperature of zero degrees Centigrade.
-This also applies to our bath fillers too.
so hopefully our customer won't have started to shampoo their hair
Heat trace the "cold" water pipe, maybe?
Why not instead make a place for the water to freeze safely without going through the pipes- e.g. Silver Iodide is much better seed than some random location in your pipe (why cloud seeding works) and when it freezes there- you can detect it easily and do something.
If some micro controls the stepper with a thermistor you could determine the last time water was flowing and how long it would take for pipe to likely freeze.  It could even cause some water to flow and warm up the pipe.
3
An impeller and a motor, where the current is not very much dependent on rotation or not, is not a good idea. At least not in small AC motors. DC motors will not last long in that environment, but react more to stalled shaft.
The simplest frozen water detector I can imagine is an AC coil with a plunger with a return spring that you put inside the coil. When you apply AC voltage, the plunger is sucked into the coil and current goes down. If the water is frozen, the plunger stays out and current will be high.
Of course, there are a lot of practical considerations, space, rust-proofing, keeping water from the electric parts and such things. But probably a lot easier than using a motor and impeller.
Gunnar Englund
www.gke.org
Dont let the hot valve open until a signal from cold water running comes first. This way your customer wont get burned
skogsgurra,
....your idea is along the lines i should have been looking for in the first place....much better than a motor....in fact, as you no doubt are aware.....your idea basically describes a solenoid.
In fact, on that point, we were considering adding some power-fail normally-closed solenoids into the cold and hot pipes, in order to handle the case when mains fails but the stepper valves are open (in some places its a legal requirement that showers shut off water in the event of a mains power fail)..now i am wondering if there is such thing as a solenoid that won't open if the water in the pipe is ice?...because if there was , then that would be "2 birds with one stone".
lukin1977, yours is a good idea also, , though slightly less sleek for our discerning customers who may find it bizarre that their shower "dribbles" before it starts up properly...though maybe we could only have the dribbling when thermistor reported zero degrees....
..anyway, i have not heard of many cheap, off-the-shelf electronic flow meters for inside water pipes, -that don't give much resistance to water flow...but worth looking in to.
Browse Omega.com for devices. If you see something that will do the job, then search for quantity pricing.
Bill
"Why not the best?"
Jimmy Carter
They are called "turbine flowmeters", essentially a small magnetic paddle wheel in a plastic housing that spins with flow, and a magnetic pickup on the outside of the housing that looks for (or counts) the pulses as the magnet spins. No spin, pulse count is less than or equal to 1, disable the hot water flow.
types:
By the way, forgive all my fellow North Americans who are not yet used to the concept of "electric showers" that provide instantaneous hot water on demand. We mostly have large hot water tanks and separate pipes throughout the house so "freeze protection" is an entirely different issue for us.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Thankyou jraef,
I am going to look for one of those flowmeters and check out the price etc.
...i just need to know "flow or no-flow" so i'm hoping i can get a cheap one...and preferably one with small paddles.
Of course, as you rightly say,  "Electric Showers"  with 10KW heaters are used in uk to get instant hot from a cold tank.
Of course, the temperature regulated showers concerning this post use pre-heated water from a large tank (and mix it with cold to get selected temperature), as you also describe.
I can just imagine that incredibly astute customer who knows that ice and water can be a slurry and the expectation that the shower water should flow even under those conditions.
"My pipes didn't break yet, your shower should have worked.  I know because when the water really freezes, then the pipes break and my shower water comes through the ceiling not through the shower nozzle."
It's harder for flowing water to freeze.
So, why not create a loop in the attic area subjectto freezing for the water to flow, having a small impeller to move the water and a small section of heat tape on the loop portion of the circuit to put additional energy into the water to keep it from freezing.  This hydraulic circuit could be automatically disabled electrically when the cold water valve was opened with a small sensor, and re-engage when it was turned off.  You could also work in an attic temperature gage to turn the system on or off at a certain temperature.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
Sorry, I'm a bit confused here. Admittedly I live in a place where freezing water pipes aren't actually a problem.
Why would you heat water up to such a temperature that it can scald people and then add cold water to cool it down?
Wouldn't a better system to be a single feed in, heat it to a controllable temperature, and leave it at that? If the upstream pipe is frozen, then there is no flow and simple detection will pick that up.
Scalding occurs at quite low water temperatures while the hot water is kept at a higher temperature (schnell says: "the temperature regulated showers concerning this post use pre-heated water from a large tank") for several reasons (dish-washing, killing bacteria like legionella etcetera).
So, in a complete system, it is necessary to do just what schnell and his colleagues do.
schnell: It could be worth-while to study that valve/sensor combination. Plunger and valve can sit in water while solenoid is outside with a stainless steel tube separating the two. Eddy currents in the stainless tube could be a problem, but I don't think it would be a major one.
Gunnar Englund
www.gke.org
You are trying to detect and protect on very fine line and a very narrow window of opportunity . If it is cold enough to freeze a valve, it won't be long before something else freezes and breaks.
If you can't or won't protect the pipes from freezing then consider a installing electrically operated stop and waste valves in a warmer area. Slope your piping and automatically drain it when the temperature of your valve is close to freezing.
Failing that the best option may be a large warning to the effect.
WARNING!!!
SCALDING HAZARD!!
IT IS THE OWNERS RESPONSIBILITY TO INSTALL THIS SYSTEM IN SUCH A WAY THAT ALL COMPONENTS ARE PROTECTED FROM FREEZING!!!
FAILURE TO HEED THIS WARNING MAY RESULT IN PERSONAL INJURY AND/OR PROPERTY DAMAGE!!!
Trying to detect freezing after it happens but before it does damage is like swinging a big stick from the small end while balancing on a knife edge.
You can probably do it but is it a good idea.
Bill
"Why not the best?"
Jimmy Carter
I can't imagine your concept being consumed by a customer who can't keep thier pipes from freezing. Luxury over basic needs.
What happens if you loose power when a correction to cold is required, besides scalding.
Here's what I'd be thinking. Consider hydraulics, and specifically an anti fall situation (in your case, anti extreme)
your flow is developed by a piloted flow control valve, each obtaining it's pilot pressure from the other source. Lack of pressure from one source prevents actuation of the other.
We are mostly technicians in here. And we may think that it is silly to detect freezing instead of preventing it.
But I am afraid that the need is real and that marketing has demanded a solution. There are so many circumstances we don't know about or can imagine.
Gunnar Englund
www.gke.org
I'm thinking, ditch the steppers.
Instead, use spring-closed PILOTED valves, driving the pilots with force motors controlled by PWM.
The cold water pilot also needs a position transducer of some sort; if the pilot won't move, the valve is frozen.
Mike Halloran
Pembroke Pines, FL, USA
Attempting to "detect ice" in shower water is not good industrial practice.  If you don't want product liability issues you need to avoid treachery like, "Is there ice or isn't there?".
You're talking about an entire product development cycle just for the ice detecting aspect.   Never go into a product development cycle and add a second one half way through, especially for an anti-lawsuit device!
Think about how a successful company would do this.   Put a thermistor on the pipe just like the others you are already using.  If it gets within 5.0F of freezing inhibit your system.  It's that simple.  No guessing required.  If the customer doesn't like seeing the system inhibited he can heat trace his cold water lines - he should anyway as that's already too close to freeze damage.
Keith Cress
Right on Keith. lps
Bill
"Why not the best?"
Jimmy Carter
Even a thermistor with a 5F limit might not work if the cold spot and frozen pipe is somewhere upstream of the thermistor, or solenoid ice detector, or whatever.  If it must be done, as Gunnar suggests, then a recycle loop should be considered.  That still only works if the recycle loop completely covers the length of cold pipe exposed to freezing conditions.
I still think some fairly simple logic would limit risk - open the cold water valve first, and verify flow (or pressure between valve and showerhead), before commanding hot water valve open.  Tell the consumer to turn the faucet on before standing under the shower head, but at worst they get a momentary squirt of ice cold water, which should serve as a wake up call to RTFM.  But a good micro should be able to sense and respond to a pressure rise (or lack thereof) in less than a tenth of a second, and either have the flows well balanced (i.e. at bathing temperature) in that time, or shutoff and illuminate the ice cube symbol.
"We are mostly technicians in here. And we may think that it is silly to detect freezing instead of preventing it.
But I am afraid that the need is real and that marketing has demanded a solution. There are so many circumstances we don't know about or can imagine. "
I strongly disagree. If the thermistor reads 0, then the system should shut down as it does now since one can conservatively reach the conclusion that 0 means ice , period.
It is ridiculous to make a system that actually detects solid ice, since 0 says if it isn't ice, it will be ice soon,
I don't see any reason to pursue any further changes in the design which I suspect has worked and would continue to work. Looks like an unnecessary makework project for someone.
Zekeman
The reality is that temperature very often 'hovers' around 0 C. The reason is that water in lakes and in snow on ground acts as a buffer that keeps temperature fixed at the 'plateau' where water freezes and ice melts. That makes the time when the shower doesn't work quite long and that is, as I understand the OP, what someone in (probably) marketing wants to avoid.
Using a thermistor with temperature tolerances that may well be a few centigrades means that you have to set the limit a few degrees above zero, which increases the span, where the shower is unnecessarily shut off, even more.
There are many reasons why this may look like a bad idea. But, can we really judge? Shall we? The original question is not about how silly or not it is to detect if water has frozen. It is about how to detect if it has frozen.
Gunnar Englund
www.gke.org
ok, now sounds reasonable.
Then I propose using a jacketed heat exchanger type entry where the hot water is in an outer jacket and the cold water flows thru the inner pipe.
Then, you can't have a freeze, without both lines frozen.
In the UK most modern domestic showers are designed to stop all flow on loss of the cold supply. This is accomplished by even the basic showers without any electronics at all, which suggests it is accomplished through a hydraulic arrangement operating on a valve. Buy one, take it to bits and see how they do it.
Check out "pressure independent valves" used in HVAC.
I would guess that a derivative of such would stay closed on no flow.
