Trouble modeling geodesic dome
I am having difficulty mating parts to create a geodesic dome model. Due to the spherical nature of the dome, the lengths of the struts used to construct individual triangles cannot be fully described by a decimal number (irrational). I am therefore forced to use distance mates on some occasions and I have to arbitrarily choose a 'close enough' distance. Is there a way to mate 'as close as possible' or some other way of accomplishing this? Also is there an equivalent for angle mates?
Thanks Everyone
-Skar81
Thanks Everyone
-Skar81
RE: Trouble modeling geodesic dome
Thank You
How you model a geodesic dome depends massively on why you are modeling it. SolidWorks does an excellent job of modeling confusion and stupidity. If the cut is difficult for you in SolidWorks, it will be difficult for the carpenter or welder or whoever.
My first thought about geodesic domes in general is that they are space frames. Space frames are ideal for maximizing access for everything in and out of the frame. This goes for you, your hands, your tools, your family, your personal belongings, rain and snow, burglars, the police, damn foreigners, animals, etc. Space frames make great jungle gyms. As shelter, a complex space frame is a way to maximize the number of seams you have to seal, somehow. A good rule for any kind of structural enclosure is that you design your covers first, then figure out the structure underneath.
Do you have to hit the diameter bang on, or you can you design a standard triangle section with rational dimensions, and hit the "diameter" approximately?
If you can design a standard connecting bracket, you can connect square cut, standard lengths of lumber, extrusion or other structural sections.
A good trick with complex frames is to create a structure shaped "blob". Make it transparent. Set the material density as low as you can. I use 0.1kg/m^3. I wish SolidWorks took into account figments of people's imaginations.
Model the blob to the outside shape that you want. Add in functional details like doors, windows, access panels, etc. Locate your geodesic pieces to the blob.
Load your blob into Custom Properties. There is a click-box that will exclude it from your bill of materials.
Your triangle section is interesting. You are aware of course that the sides of your lumber cannot be perpendicular to the faces. You might be able to do this with a table saw or circular saw, but you will need some sort of jigging procedure to make up for tolerance stack-up.
It works fine and allows for metric/English units if need be.
(For instance, the belts/pulleys might be metric, but the pulley shaft centerlines, etc might be better to remain in English units)
I've also used this for Chains/Sprockets because the dimensions often don't come out to the nearest common decimal, but yet, the accumulated link(s) dimensions must be held.
If the triangle shape & dimensions present problems with mating; applying the "close to" modified mate to the geodesic form might be the way to go....as long as there aren't any further "stack-up" problems.
Dan
www.eltronresearch.com
Dan's Blog
Push the solid bodies out to assembly and Fix.
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
The relationship between diameter and any linear measurement around a circle or sphere, is an irrational number. You are going to have a round-off error.
How accurate is your carpentery? ±1/16"? I can set my circular saw at home to within one degree. I suppose a good table saw can do somewhat better. All of these tolerances will accumulate as you add pieces to quite a substantial error. You are going to need some sort of surveying and jigging process.
Your round-off error is trivial.
The solution is to model as multibody (and/or skeletal modeling techniques) and forget assembly constaints altogether (not needed).
I think that modeling in SolidWorks is fairly easy. Define a centre axis. Insert the first element of each row. Create a circular array for the row.
Assembly of this thing is going to be a challenge.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
