how tight is too tight?
I started a new job recently at a district energy centre. And one of the parts of my job is construction supervisor for all the various energy units. And part of that job is ensuring everything meets requirements based on various testing, notably pressure tests.
At my last job, in a different industry we would have to do pressure tests, but they weren't critical and if the system held pressure for a couple hours we were just gave them a pass. No trending of pressure, etc.
But at this new job, we test to the consultant's required specs. And I find most tests are technically failing, but I feel like the test results show the systems are good enough to a warrant a pass. But regardless, they didn't meet the spec, the test failed and they have to redo it. And of course I'm the one that gets to tell the contractors, with years of experience, to do it all over again because they dropped 1 or 2 psi outside the allowed range.
Does anyone else feel like specifications sometimes are a little too tight? I feel like if the consultants were on the site looking at the systems, they'd give them a passing grade, but they're not, and it's me who is obligated to say that the test failed or take on the responsibility myself.
How do you guys handle that situation? If I was in the contractors shoes I'd think my company is ridiculous for these tight specifications.
Maybe I'm just venting over my frustration with consultants who are sitting in an office 100 kms away (no offense to those who are consultants).
RE: how tight is too tight?
Standards exist for a reason. In this case, it is not your job to pick them, only to test them and report the results. If they wanted you to have "wiggle room" they would have put words like "professional judgement" in the requirements, not numerical pressure readings.
You wouldn't want a heart surgeon to have gotten a grade of "not technically passing, but close enough because they were being picky" and sent on his way into your heart.
-- MechEng2005
Just feel like it's tedious. But you're right, and they're re-doing it on Monday.
Thanks for the input.
- Steve
Leakage at a known location might give sufficient reason to not require repeating a test. Leakage from a valve packing is such an example. Do you de-pressurize, fix the valve packing and then repeat the test, or do you pass it because you know where the leak was? That's a judgment call, and unfortunately it's your client's judgment rather than yours.
Yes, it's possible for a test criterion to be set too stringently by an ignorant client. Sometimes this requires that the system be broken into smaller pieces to permit testing, leaving the connections BETWEEN these pieces untested or incompletely tested. That is not in the client's interest.
It's also possible to do a hydrotest poorly enough, i.e. by not ensuring that the equipment is 100% full of water without any trapped air, for a test to pass despite significant leakage.
But as someone said, the test requirements are in the specs when the contractors bid. They should be aware and do the test in a manner they should pass.
I feel like their work is good enough to pass, maybe they just need to do conduct the test differently...
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
So no corrective action? Just repeat the test and hope it passes the second time?
And if it doesn't pass the second time just keep testing until it passes?
Most likely you have pass/fail criteria that are based on "design nominal" values, with some arbitrarily assigned range tack on.
Properly chosen pass/fail criteria need to take into account process variability and instrumentation error.
Pass/Fail...really simple. No interpretation required.
TTFN
Chinese prisoner wins Nobel Peace Prize
But, if the test fails again, they'll have to do it a third time, isolating the suspective cause. And if it turns out that after isolating the valve the system passes, we'll probably just give them a pass on the whole system since it is a non critical leak.
I'd say it was pointless, but I think there is something to say about holding them accountable and making sure they know that we will not let just anything pass.
It's still tough sometimes when you feel like you're splitting hairs. But I do not want to be repeating to a jury that it was close to passing....
TTFN
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
No, they should do the work such that the system passes because it is to spec. Not tweek the test so that the system passes.
Peter Stockhausen ://www.lin kedin.com/ profile/vi ew?id=3006 4526&t rk=tab_pro
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
http
While retesting without correction is often done, and the next time the test is run, the article often passes. This is usually an indication of a unreliable test, and raises the issue of whether a critical leak actually exists, but just was caught the testing. That would be a bad deal all around.
TTFN
I agree with many of the comments made. I feel this spec is somewhat flawed but at the same time the crew approached it in a flawed manner as well. this second time, they were more careful with conditions (temperature variations) and the results were better. Too bad they didn't take those precautions the first time.
Anyway, I hope the next time they're working on our equipment they keep in mind the fact I will only pass a test that meets the passing criteria and they'll do it properly the first time.
I appreciate the comments though. I like getting input from other engineers who have been in similar situations.
Cheers.
i remember a job awhile ago when we were testing a system (a whole airplane's load of systems). we took the prime's spec's and determined we needed a really special ground cart to create the conditions required by the specs. when this was presented back to the prime the reaction was "what, are we building a plane that can't use a standard Hobart ground cart?" "no, we need this to cover the spec requirements." "well that's just dumb ... we never had to do this before (when we tested ourselves)"
Your job is definitely NOT to turn a blind eye and pass things. If you feel the spec is too tight, pass your comments up/across the chain, with all your reasoning, and see what your feedback does.
You never know, you may have someone thank you. Odds are though, you'll be politely ignored.
In another company I helped introduce fracture mechanics analysis for structural welds with defects. That got the attention of a lot of people in USAF. There is a place for debating the means of accepting less than specified results in mfg.
It's not that I'm combattative with the design team. It's that I have the luxury of being able to relatively quickly test things like this when the design team never comes within 50 miles of the parts. We are able to provide them with data about how the parts hold up when certain parameters are loosened. And sometimes things fail dramatically, and sometimes they fail undramatically, and sometimes they're just worringly enough out of spec to make me not want to question it. But sometimes there's no realistic change there at all.
None of this whatsoever says that you can justify ignoring or getting wiggle room specs. Follow the specs vigorously while they're the specs. But I think it's healthy to question them in ways that are valid both from a design as well as a use perspective. You might find some "well, it's always been like that" type situations that can be worked around to the benefit of all.
