208v electrical heater works fine in 240v?
i have a dayton 2yu74 electrical heater, in the plate said 15Kw, 60 Hz, control voltage 24v, 208V, 1/3 fase.
could this unit works fine if is connected to 240 v?
RE: 208v electrical heater works fine in 240v?
Keith Cress
That is exactly what happend, the owner of the place call me to fix his heater, after changing the fuse, the heater is still no working, so i found that the transformer for the control voltage is burn, i replaced it and after work for a minute, the transformer is burn again, then i check the plate and i saw the current voltage, now the unit is burn.
Bill
"Why not the best?"
Jimmy Carter
