Section Views displaying wrong objects
I have been having this problem recently with SW2010.  When I create a section view it is displaying some objects of the model that are BEHIND the view.  It just started doing this recently, and I haven't changed any of the settings, as far as I know. Has anyone had this problem?
As you can see in the attachment, there are gussets on the left and right sides of this structure. When I section it in the middle, with arrows pointing left, it is showing the gussets on the right side, which are behind the section.
RE: Section Views displaying wrong objects
If you go to the part/assembly level and section the part do you get the same result?
This would allow you to narrow it down between the drawing or the part/assembly.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Is there any chance you have a configuration where the gussets are not mated/located correctly?  Are the gussets somehow defined as fasteners and being excluded from the section cut?
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
In the tree view, scroll down to "More Properties", go to the tab "Hide/Show Components", select the parts you want to hide.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Have you submitted this to your VAR?
SBaugh - It sections correctly at the Model level
JMarv - The gussets are fully mated and located correctly in the model. They are simple extrusions, not fasteners of from the Toolbox.
Ctopher - I can do that for this time, but need to find the problem. I think it lies somewhere in my settings.
Has anyone had a situation where their SW software just started doing weird things and/or crapped out?
Dzine3D ... Are you able to ZIP and post the parts, assy & drawing for testing on other machines?
ctopher - NVIDIA Quadro FX 4800. I've never had other graphics issues, except when dealing with parts in the 100mb range.
