Variable fillet--UNassign value to vertex???
Working with variable radius fillets. Finding that once a vertex has been assigned a radius, it can't be returned to "unassigned". This is a problem, as I want to have the transition occur across two segments, and I want to remove the value assigned to the vertex that is in between.
Is there a way to unassign a radius on a vertex in a variable radius fillet?
RE: Variable fillet--UNassign value to vertex???
Dan
www.eltronresearch.com
Dan's Blog
