question regarding screen layout
hi!
there's the possibility that i'm thinking computervision here but..
i would like to know if it's possible to have the screen split into 4 (or 6) separate views.
i haven't worked ug/nx since v18 and the job i'm working on in nx6 would go a lot smoother if i could see the same features in different views at the same time.
thanks!
ted kralovic
liverpool, ny
VisVSA, NX-6
RE: question regarding screen layout
Can't remember where it is n the view menu but you're looking for layouts
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5
namdaci45:
thank you!
view>layout>open and choose your weapon!
ted kralovic
liverpool, ny
VisVSA, NX-6
control+shift+O gets you there as well
You can also use the following new functionality:
Window / New Window
then
Window / Tile Horizontaly
Its more windows like
Didier Psaltopoulos
http://www.psi-cad.com
