Composite beam studs/rib
I have a question on designing composite steel beams. RAM steel will give a minimum number of studs but I'm not sure how to make proper use of it.
For example, I'm designing a 30' long beam with deck perpendicular to the beam. The deck has rib spacing of 12" oc. But RAM tells me the number of studs as 42, and I've seen a number of engineers basically just call that number out.
My question is, how do they figure out how to "uniformly" space 42 studs in 30 deck ribs? Do they automatically just say "that's more than 1 stud per rib so let's put in two studs per rib"? If so it would make sense to automatically jump from 30 studs to 60, no? I'm just trying to figure how to do this economically since RAM gives you the bare minimum (sometimes with less than 0.1 kip*ft to spare on the moment capacity) and I'm trying to balance upsizing the beams one size versus more studs.
Thoughts?
Thoughts?
RE: Composite beam studs/rib
There is a rule of thumb for how much an installed stud equals in pounds of steel, worth googling under current economic conditions. Sometimes its better to upsize, studs are not free.
In the end, economy will dictate your best option.
BA
