Setting up ANSYS geometry "fluid volume' for subsequent meshing,..
I have used CATIA to create a nozzle whose shape equations I know.
I did this by defining working supports and creating the curve{shape} of the nozzle by a law{my equations}.
I then created the surfaces of revolution about the respective working support.
I then used the thick volume to make the walls of the nozzle 1mm thick.
This was then imported into ANSYS geometry.
In order to define a 'working volume' for the fluid flow in the nozzle, I followed the video demo from ansys below(2min long):
B Valve – Creating A CFD Solid Using ANSYS DesignModeler
In this demonstration, we will review the process of connecting to a
parametric CAD assembly and using ANSYS DesignModeler to extract the
fluid volume to be used for a CFD study.
http://www.ansys.com/staticassets/ANSYS/staticassets/resourcelibrary/demo/32-Ball-Valve-Creating-CFD-Solid.swf
My problem is that I do NOT get TWO solids after using ENCLOSURE.
It is though my imported geometry does not exist, even though it is there.
What am I missing here ??????????????????
I would greatly appreciate any help here.
[I am a novice to ansys and catia, and am learning on the fly.]
