Cell Library Disappearing!
I've been working on a project that has a certain cell library attached to each MS file. For the last year, the line terminator has worked perfectly. Now, in a few files, when I go to terminate a line using the "Place Active Line Terminator", there is no cell recognized. When I go to "Cells" to check it out, there are NO cells in the library I have attached - it is completely blank. I go into other files and it's working fine. I recreated the LT cell, but this only worked for awhile. I also replaced the cell library on my hard drive with a previously saved version. No dice.
Does anyone have any ideas? Are there settings I'm missing?
Thanks for you help in advance.
p.s. Sorry I couldn't help you with that last question, Rob the Poser - I rarely use that feature!
RE: Cell Library Disappearing!
