Micro Ceramic Bearings
I'm looking for sources for ceramic bearing vendors, and their use.  Preferably in the USA.  I have an application for a ceramic bearing in the neighborhood of .047" [1.2mm] ID bearing, .125" [3.2mm] L.  All my search efforts are only churning up hits for RC cars and skateboards applications, I'm more interested in micro fan-like applications.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Micro Ceramic Bearings
You might try Bird Precision.
You probably wont have much luck outside China for ceramic ball bearings.  I got some for for 3mm shaft.  Not very smooth.
With ceramic it is difficult to achieve the tolerances you can get with steel.
Jewel bearings might be a better option.  A ruby plain bearing on metal spindle.
As ornerynorsk said.  Bird Precision have a good range of jewel bearings.
Thanks for the lead.  I should have been more specific, looking for plain sleeve bearings, not ball bearings.  We hadn't considered jewels.
