Rotating a spline to match up with an existing sketch
Howdy all,
So I've got two point clouds for the top and bottom of a part.  The top has a curved surface from which I've extracted a curve using a spline to match a section of the points.  Now I want to use this on the sketch I've created from the point cloud of the bottom but when I try and rotate it the spline handels do not rotate and it distorts my spline.  Translating the spline is not a problem.  If anyone has a solution for this problem please let me know.  Thanks.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Rotating a spline to match up with an existing sketch
Use the Convert Entities tool to create a non-spline sketch, then copy and rotate that sketch.
-or-
Create a surface from the spline, then copy and rotate the surface and use the edge of the surface for .... whatever it is you are trying to do.
Thanks CBL.  I had trouble at first because I tried your suggestion in the part I was working on, but converting an entity makes it fully constrained.  If I just took the spline and performed convert entities in that sketch and _then_ copied (which looking back is what you wrote) It worked.  Those little details make a difference.  Now to do it again for a different section so I can do a lofted cut.
-Kirby
Kirby Wilkerson
