Transparent parts in assembly drawing - Best Practice
Here's my problem:
I have a motherload of piping situated inside a frame. When I make a drawing I want the frame to be shown with dashed lines and I want it to be transparent so I can see all piping components, even when they are hidden behind beams.
What is the best way to achieve this?
RE: Transparent parts in assembly drawing - Best Practice
Another is to create configs (frame suppressed and unsuppressed), and then use the Alternate Position function to show both configs on the one view.
http:/
Is it possible to set only the frame to 'shaded with edges' and leave all other components in wireframe?
An alternate pos. method means you can't make cutouts, but that's about it I think when it comes to drawbacks.
I was wondering if there is a more straightforward method available, like a 'transparent' setting per component for drawings, but apparently there isn't(?)
