CAM UDE Sequence Numbering Help
I have am using the NX7.5.1.5 and I have a block of UDE's in a machine control operation.
I have tried using the Sequence Number UDE, but I just can't get the format right. Usually I get it so every event in the block is numbered, but I just want it named at the start of the block, if that is possible.
Does anyone know how to get a sequence number (NXXX) before a group of UDE's?
example:
N10
N20
N30
N40
N50
N60 (NX OPER NAME: CENTER_DRILL)
N065 (NX OPER NAME: MACHINE_CONTROL)
M69
M25
G330
M434
N070 (NX OPER NAME: ROUGH_TURN)
etc
example:
N10
N20
N30
N40
N50
M69
M25
G330
M434
etc
RE: CAM UDE Sequence Numbering Help
I talked to GTAC. They had no problems getting the correct Sequence number from what was in my post processor. After some time trying to find what was different. I was using NX 7.5.1.5 and they were using 7.5.2 so I am currently downloading the maintenance pack.
I don't know what's in the maintenance pack that would make a difference, but I do believe that is the solution.
Thanks for the post.
