[B]Opinions on Solid Edge[/B]
We are currently looking at replacing our existing 3D modeling and 2D design package with another system and would like user opinions on Solid Edge. What does it do well, how easy is it to use, any bad points, annoyances or bugs etc?
We would be using it to create 3D solid models for NC programming and for creating 2D machining detail drawings from the solid.
Your opinions would be appreciated.
RE: [B]Opinions on Solid Edge[/B]
Easy to use.
Use 'traditional' parametric modelling or direct modelling or combine the two in a single model.
Direct modelling lets you modify imported models.
Handles very large assemblies well.
Does not require super-powerfull hardware (unless you are doing REALLy massive assemblies of several hundred thousand parts)
Excellent 2D drafting from 3D models.
2D Drafting can be used stand-alone.
Weaknesses:
Complex surfaces.
Probably not as many 3rd Party add-ons as some other systems.
Bad Points:
Can't think of anything really. Many improvements have been made over last 2 releases especially. Now, even I have grown to like the interface - and I was one of its biggest critics.
Annoyances:
In my opinion some small changes are still requred to the drafting interface, just to save few mose clicks here and there - but that is just my opinion.
Bugs:
Can't think of any at the moment, but I'm using ST2 not ST3
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
We're considering moving away from SE because some of our management have got hung up on the above issues, however as an actual user I'm not saying my management are right in how much weight they attach to those issues.
As a program I'd say it's broadly comparable with the other 'Solid' competition. We're a few versions behind on SE (V19, pre synchronous), and I just went and did training on the latest version of Solid Works, 2011. Overall Solid Works 2011 was slightly better, but it's about 5 years newer than our SE version. I'd love to have a go on the latest Solid Edge to see how it compares.
I will say I think Solid Edge is still ahead in the 2D drafting, though I didn't do enough in the Solid Works training to be too sure.
However, depending on what you're doing SE's ability to treat imported geometry almost as native may be a big advantage over the opposition.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"Solid Edge ST3" or"Solid Edge ST3 versus SolidWorks"
BTW - I work on the FEA code for Solid Edge
Pro/E just recently died and got reborn as Creo
Autodesk Inventors fusion technology is still in beta.
Solid Works big change (going all cloudy + switching modeling kernel) is still a few years into the future, which makes it currently the least recommendable mid-range cad package on the market.
I have a friend that got a job at a startup company that had gotten a "nice price" for NX+Teamcenter.
No evaluation had been made someone had just thought that if it's good enough for the automobile industry then it must be good enough for us, oh and look at that shiny low price tag...
Turns out is wasn't good enough for them and the consultant hours required for getting Teamcenter up and running ate up the price tag really fast. Now they are looking at throwing out both the cad system and pdm system and replacing it with an Autodesk solution (Inventor+?).
So the moral of this story is: Do a proper evaluation, get the supplier to demo the products and also get to try them yourself for a few weeks. Then make the decision.
If everyone went down that route we'd all still be using AutoCad 2D (or still working on drawing boards)
Yes, you need to consider suppliers needs etc. but that should not be the only criteria.
You have to make sure whatever product you choose will do the job that you need it to do, so make sure you get to try it on your own products.
Draw up a check list of what you need.
How complex are your parts - simple machined or complex curved surfaces?
What type of parts - cast, machined, sheet metal ? (SE has excellent sheet metal capabilities.)
How complex are the assemblies - how many parts at final product stage? I have over 100,000 parts in the top-level assembly.
What will the hardware requirements be?
(I'm running on a 2.4GHz quad core with 4GB ram, on 32-bit SE - it is a bit slow at times but it does it. We find the network is the main sticking point)
Pick a few parts and assemblies that encompass everything you do and get the vendor to model them and create drawings etc. at YOUR site so you can watch and have a go while they do it.
Also get them to show you how to handle big assemblies, how you copy and rename files; how to set, change and use file properties etc.
Also post the same thread on other system's forums.
I can almost guarantee you will get the same answers.
bc.
Quadro FX4600.
I've been using SE from V14 to ST2 the last 6 years and now I've been using SW 2010 since July. The biggest difference between the two that I've noticed thus far, is that SW has more advanced feature for the assembly part at the expense of good usability for large assemblies compared to SE. But if you're not planning on doing much assemblies anyway I would choose SE in an heartbeat only for Synchronous technology. Because for the history part of both softwares they are pretty even.
Like others have said it really depends on what you need from the software because they both have their strong point.
My 2 cents
Patrick
Eidt parts directly in an assembly is not good
2D is in many ways not very good
No family tables
Pattern function is not good
Synchronous technology is filled with errors.
Synchronous technology is a nightmare if you want to edit your parts.
Many claims that sheet metal in Solid Edge should be particulary good compared to other programs, this is not my experience.
Solid Edge is relatively easy to learn compared to for example Pro Engineer.
I used ProE and their technical support was excellent (some might say it needed to be) However I preferred ProE. Seemed more structured. Sales always pushing stuff you didn't need or want.
Performance on big assemblies will depend to a large extent on how you use it, your hardware and the network.
Parts can be dimensionally edited directly from an assembly by use of the variable table, or double-click to open it in the context of the assembly, or RMB and 'Open' to open the part exclusively. Similar for sub-assemblies.
However, you cannot see all the structure of each individual part from an assembly. Personally I find this a blessing with large assemblies.
2D drafting - what isn't very good? Can you be specific.
I've never been unable to produce the drawing I need.
Patterns - again can you be specific?
Synchronous Technology is still in development, so there are bound to be limitations.
Sheet metal works OK and has some good features, but as with any mid-range modeller there will be limitations. It does not handle material deformation for example.
bc.
Quadro FX4600.
If you are in the US you have direct access to corporate support from Seimans for Solid Edge (GTAC). They are very good. Outside the US you have to go through the VAR.
thread724-223361: Factors to consider when choosing a CAD Package may be of use for tips on general comparison of software etc.
bc.
Quadro FX4600.
this is one of many many examples of little things that add up to make it generally harder to use. Not "hard" to use, just if you're used to the freedom you get in SW, it's a real pain going back like I've had to.
If you want to make a protrusion, start with a protrusion. Simple. If you want to make it off an existing sketch, select it. If you don't want to, create a new profile on the fly. There are many ways to get to the same end geometry. You don't have to do it exactly one way.
--Scott
http://wertel.eng.pro
I had to try really hard not to do that when I was in SW training a couple weeks back. Initially it seemed really clunky having to create a sketch first etc. Then I thought about it some more and creating the sketch and then choosing if it's going to be a protrusion or cut straight from the sketch isn't that much different from SE.
Unlike SE (if I remember correctly), SW does not offer the ability to create sketch planes "on the fly". That is why the workflow leans toward creating the plane, and often the sketch, before selecting the function.
Although, for an error prone dufus like me who occasionally hits 'protrusion' rather than 'cut' by accident, the more typical SW work flow has advantages!
Certainly it seems mulledmind wasn't using the usual SE work flow.
I'm totally with you on that Kenat. Especially if you've been using it for a long time.
If we are in the comparisons between SE and SW after 8 months on SW following 6 years of SE I'm missing the following features from SE:
- Open profiles.
- Draft environment.
- Revision manager. (This utility is surprisingly useful)
- System library.
- View orientations. (I don't remember how the button is called)
- Exploded view environment.
- Synchronous.
- Part copy.
There are a couple more but they may just be a mater of taste.
What I do appreciate from SW thus far:
- Advanced features in assembly. (Constraints with limits)
- Multiple body in part.
- Symmetrical components in assembly.
- Hole table.
I don't have time to get into the details of this comparison but if you have questions don't hesitate to ask.
Patrick
Open Profiles - exactly what it means. A sketch profile for a cut or protrusion (other than the base protrusion) does not have to be closed. Some profiles (sweep and loft) must be closed.
Draft environment - is (in my opinion) superb, especially with recent improvements to Parts Lists. The only downside of drafting is you can't change a view orientation once placed. Drafts of big assemblies can be opened 'inactive' which means the model data is not referenced, thus reducing memory usage drastically. You can dimension, add and change notes etc. with inactive enabled.
To update the views you just activate them.
Revision Manager - everything SW Explorer should be. Copy, rename, replace parts in an assembly, find all the drawings and assemblies used by every part and sub-assembly and maintain all links during the operation.
I've done a copy of a top-level assembly with 30K parts and 1000 associated drawings for a new project.
Along with Revision Manager I would list Property Manager -something I've seen asked for on the SW forum - a 'spread-sheet-like' facility for modifying (and creating) custom file properties for all SE file types.
System Library - saves a group of parts and/or assemblies with all their inter-part constraints (mates for SW users). Also saves the positioning relationships required for the group and prompts the user for the related faces during placement.
A similar facility is the Capture Fit command. This saves the pisioning constraints of a part/assembly within the part/assembly file, so next time you place it you will just be prompted for the faces to relate to. It's a simple one-click on the part/assembly. The bonus here is that the capture fit can be done temporarily, just for that design session, so you can use different constraints to the ones saved.
bc.
Quadro FX4600.
I noticed the advantages SW had in assy, I wasn't sure if it was just because I'm on an old version of SE (V19) while our training was on SW2011.
The fact that you're all saying I don't use the right workflow proves my point. In SE, you are forced to use their workflow rather than the one you're most comfortable with..
The reason I create a sketch first, is because If you select protrusion, and sketch within it, it swallows the sketch and you can't access it again to use it for another feature. In SW, the sketch becomes a sub feature of the protrusion and can then be used to make other features. Either way, SE is much more prone to forcing you to do things exactly the way it wants instead of letting you choose.
Here's another example:
You are making a sketch, and you want to make two lines colinear. In SW, you can either select both lines, then press the colinear button, or press the colinear button, then select both lines. In SE, you have to press the button then select the lines. This is a very small example, but it's consistent across the program and makes it very frustrating after a while. Personally, just habit, I like to select the lines first then hit colinear, but I don't get that option. Same goes when creating a sketch, you can't select a plane, then click the "create a sketch" button, you are forced to hit the button, then select the plane.
I realise these sound like small nit picky things, but it's an entire pattern. You are forced to go in a specific order to do these things in SE whereas SW gives you more freedom to do the work in a manner that suits you personally.
A lot of people don't mind this and those trained on SE who never use SW probably would never have a problem with it, but it really bugs me and I thought the asker might like to know in case that would bug him too.
I've already asked for a way to replace/copy/rename files in SW and the only solution there is, is to use the pack'n go features with the replace command. It can do the trick with some hassle but the Revision manager (and also the property manager) are a lot more powerful and easy to use in SE.
The closest thing there is in SW to the System library is the copy with mates feature. But in SW it's limited to the same assembly when in SE the information is stored in the parts or asm itself so you can bring a bunch of parts to a completely different asm very easily. The only workaround to this in SW is to save as the whole assembly, then open it, delete the unwanted parts, save, then import in the new asm, then reorder, etc.
In SE there is a feature you can use to orient the view of the model. It opens up a little cube in isometric view and depending on which faces or edge you click on the cube the view of the model spins in the right direction. The advantage of this is to be able to have a view oriented in any way with straight edge instead of positionning it loosely with the mouse. I agree it's no deal breaker but it's still very useful to me.
For the exploded views environment it's kind of difficult to explain but to me it seems a lot intuitive.
For Synchronous there are a lot of dicussion of it out there. I don't use it much but it's very strong on imported geometry.
For part copy there is the same options in SW where you can insert a part inside another part to copy the geometry while keeping the reference to the original but what I prefer in SE is the ability to bring the part as a construction geometry only instead of a solid model. That way I can use the construction geometry as a skeleton for another part.
Patrick
About the colinear example I agree it's more intuitive especially in the beginning because you can see the options available to you with what you selected. I think it's a good thing in general but when you start working on larger assemblies or parts with lot's of features, SW tends to search for options a little too much for my taste and then it's slow to respond.
Patrick
http://www
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
