Propane condenser
Propane condenser
We have an air cooled propane condenser. The condenser is located at the high point in the discharge piping of the compressor. The inlet and outlet piping to/from the condenser are from the bottom. Short of CFD analysis, is anyone aware of calculations that can be done to confirm if non-condensables (inerts) can accumulate in the propane condenser?
Our contractor is proposing calculations based on Froude number and buoyancy factors to demonstrate that non-condesables will not accumulate in the condenser, even though the condenser is at the high point in the system.
RE: Propane condenser
Likewise a bottom drain poit to get the butanes out should be installed. Stratification will occur.
