two amplitudes
two amplitudes
how to impose two amplitudes simultaneously to the boundary conditions
RE: two amplitudes
*BOUNDARY, AMPLITUDE=<amp2>
etc etc
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
RE: two amplitudes
thanks
RE: two amplitudes
If the amplitudes are supposed to applied to the same part in different steps then that will work too. Just edit the BC in the appropriate step and change the amplitude.
If you want to apply two displacement amplitudes to the same part instance in the same step I am not sure you can, or why you would want to.
RE: two amplitudes
yes i want to apply Two boundary conditions (displacement + rotation) amplitudes to the same part instance in the same step.
I tried and it works using "velocity / Angular velocity" (without amplitudes)..
but it does not work with "Displacement / Rotation" amplitudes.
RE: two amplitudes
