Compile Problem
Compile Problem
Compile Problem
I have the following similified code running in Excel.
CODE
    Dim objDoc As SolidEdgeDraft.DraftDocument
    On Error Resume Next
    ' Make sure SolidEdge is already open
    Set objApp = GetObject(, "SolidEdge.Application")
    If ((Err) Or (objApp Is Nothing)) Then
        MsgBox "Solid Edge must be running."
        Exit Function
    End If
    ' Make sure the active environment is Draft.
    If (objApp.ActiveEnvironment <> "Detail") Then
        MsgBox "You must be in the Draft environment."
        Exit Function
    End If
    For i = 0 To objApp.Documents.Count
        Set objDoc = objApp.Documents(i)
        If (objDoc.Type = igDraftDocument) Then
            objDoc.Activate
        end if
    next
When I run it on one computer everything is fine, however when I run it on another the VBA editor gives the following error:
Compile error:
Method or data member not found
and points to the line 'If (objDoc.Type = igDraftDocument) Then'
implying objdoc does not have a type data member.
How can this run on one computer and not another.
To add to the confusion, this is an EXACT copy of another program only with a few additions which works on BOTH machines without problem!!!
Can anyone shed some light on this please?
RE: Compile Problem
Do you have all the same reference libraries on each machine?
