Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
il89 (Civil/Environmental)
2 Feb 11 19:57
In SAP2000 v14, Would I be able to disable the AISC Code design check after running load cases? if so, How? and would I be able to define my own design limits (For example, yield stress) for certain members?
masomenos (Civil/Environmental)
8 Feb 11 11:19
I don't understand your issue regarding disabling the AISC design check.. because you have to run a separate design check after the analysis in order to obtain design code results. If you just run the analysis by itself there will be no design check. If you run an analysis, results from your load combos will be available as you defined them. "Stress" results will not be available with frame elements using analysis only.. stress will be reported only for area and solid elements
Close Box
Join Eng-Tips® Today!
Join Us             Close
