what is the allowable leakage from a air tight room.
As the title already indicates, what is the allowable leakage for an air tight room?
RE: what is the allowable leakage from a air tight room.
The air leakage rate must not exceed 2 L/s.m² 75 Pa (0.4 cfm/ sf 1.57 psf) when tested according to ASTM E779.
