IS THERE A FUNCTION TO DETERMINE ODD AND EVEN NUMBERS
Hi everyone
I'm in nx6 and trying to create an if/then based on X being odd or even.  example if(x==odd)(1)else(0)
Is there such a function or work around?
thanks for your time.
RE: IS THERE A FUNCTION TO DETERMINE ODD AND EVEN NUMBERS
OK, try this:
test=mod(x,2)
If x is ODD, test=1
If x is EVEN, test=0
Note that 'mod' is known as the 'Modulus' function and is documented in the Expression system's Function section under 'Math'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
And if there's a chance that 'x' could be positive or negative, it's safer to write the forumla as...
test=mod(abs(x),2)
...as this will remove the effect of the sign of 'x' from the value of 'test'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
That worked great, thanks for the help.
